[SOLVED] Planning on upgrading my first PC build :) Really need help!
themiziko
63
Hello everyone! after 3 years I decided to upgrade my first build. I'm quite lost as to which parts to upgrade/change :) My current budget is somewhere around 1000-1100$. I use my PC for pretty sizable illustration/drawing in Photoshop and Gaming :) I attached all my current components, Imgur link to photos from inside the PC, and benchmarks. Any advice would be greatly appreciated!
https://www.userbenchmark.com/UserRun/5860441
View: https://imgur.com/a/BsnF2r8
Graphics: GTX 1080 8GB
Case: Spec01 Corsair carbide MIDI
SSD: 250gb EVO SAMSUNG 960 (used 100% for the system, I have a separate 500gb SSD for Games)
HDD : 2TB ST2000DM006 SEGATE BARRACUDA (For Photoshop files, etc.)
Ram: DDR4 16GB LPX 2400MHz COSAIR VENGANCE
Processor: 17-7700k 4.2GHz 1151
Motherboard: MSI Gaming M3 z270 DDR4 s1151
Ventilation: CPU BK009 PURE ROCK Be Quiet!
I also have 2x 27 inch monitors
MG279Q ASUS 144hz
IIyama PL2792Q 60hz
And one 43 inch 4k monitor I only use when playing Games: LG 43UD79-B
Haha, I apologize 😀 I copied all components from my receipt from 3 years ago, and apparently, I either overclocked my processor or bought additional RAM. View: https://imgur.com/a/mdFRpU5
Does it change any of the components you recommended? :) because from what I checked, they are very good picks and easily available in Europe, so the shipping would not be an issue :)
yep, no need for a ram upgrade. 32gb is a ton. Go straight for the i7-9700k and the 2080 super.
I would upgrade the cpu starting off. an Intel Core I7-9700K Coffee Lake 8-Core 3.6 Ghz (4.9 Ghz Turbo) should be a good upgrade from your i7-7700k. upgrading to 32gb ram would also be beneficial. G.SKILL RIPJAWS V series is good. The graphics card is pretty good, but if you want to upgrade that as well, the 2070 or 2080 super are great options.
Reactions: themiziko
HOL UP u said u have 16gb ram but the userbenchmark shows 32gb
