I have been trying to get windows xp64 to understand the drivers that I make with the "make disk" utility on the Asus CD, but it just won't understand the drivers. I'm using the nvidiaRAID (not the Silicon Imaging) and I've set up the array just fine (the bios sees it perfeclty) - the windows xp F6 just doesn't work!
I'm installing windows xp64 just fine on a single drive right now... is there any way I can RAID it after installing windows?
Thanks a bunch,
Tony :!: :!:
Thanks a bunch,
Tony :!: :!:
