I have a Viewsonic P95F+b 19" aperture grille CRT, and I'm having a really strange problem. Long (horizontal) areas of dark color throw the image out of horizontal alignment. For example:
<pre> +==========================+
| +---BLACK----+ |
| +----BOX-----+ |
+==========================+</pre><p>I can create a new layer in Photoshop, draw a thick, black stripe, and when I drag it up and down, I can watch the image in the horizontal area of my screen distort, which makes pixel-precise work almost impossible.
The darker the color and the longer the area, the further out of alignment the parts of the image will shift. None of the built-in adjustments seem to help, but the problem does get worse as brightness is increased. At 85% brightness in the monitor's Normal mode, it is rather noticeable, and it only gets worse from there.
It's not such a problem during web surfing or gaming, but being a web designer and a photographer, it's really impeding my work. What could possibly be causing this problem, and (I probably already know the answer to this) is there any way I can fix it? Thanks in advance.
<b>UPDATE:</b> I just realized that the severity of the distortion is also affected by the proximity of the dark area to the edge of the screen. The further away the object is, the less severely it will affect the rest of the screen.
Also, the distortion is as diagrammed above, with the parts of the image shifted to the left. Also, I should mention that the problem is not related to the stabilizing wires, both of which are in perfect alignment (until you drag a dark area across one of them, of course).
Thanks again, everyone.<P ID="edit"><FONT SIZE=-1><EM>Edited by thealtkey on 08/17/05 03:18 AM.</EM></FONT></P>
| +---BLACK----+ |
| +----BOX-----+ |
