Question please help!! I am building a PC with Ryzen 7 3700x, RTX 2070 super and the Asus Tuf x570 plus mobo. Need help with choosing a psu
Sep 28, 2020
As mentioned in the title, I am building the PC with those specs. This is my first build. I got a new packed Antec VP630F psu from a friend. I know this psu is quite old and the OEM for this model is Delta Electronics. I read online and it seems like this power supply has all the necessary features like over-heat protection, over-current protection, over-voltage protection, overpower protection, under-voltage protection and it is 80+ certified
Would this power supply be okay for my build? I think I can also go to Bestbuy and get the Corsair CX750M, it is around $105. Would going with Corsair be a better option or the Antec power supply should be fine?
Thank you in advance.
Barty1884
The PSU was pretty good....in it's day. It's day was ~7 years ago though.
It would probably do the job, but I'd suggest a newer unit & maybe flipping the VP630F to cover some of the cost.
Even a quality 650W unit would be plenty here - and you could get the SeaSonic made Antec Earthwatts Gold Pro 650W for $95:
https://pcpartpicker.com/product/B9CD4D/antec-earthwatts-gold-pro-650w-80-gold-certified-semi-modular-atx-power-supply-ea650g-pro
or the 750W unit for $105 - a better 'value' for the quality you get vs the CX750M
https://pcpartpicker.com/product/TDjJ7P/antec-earthwatts-gold-pro-750w-80-gold-certified-semi-modular-atx-power-supply-ea750g-pro
Reactions: BogdanH
