Please help me pick a case
damithagg
45
I'm doing a first time build
parts I have so far are
AMD X4 635
MSI 785GM
OCZ RAM DDR3 1600
Thermaltake V1 Heatsink
Hitachi 1TB HD
HD 4850
OCZ 550W PSU
Trying to get my case and am stuck . I like These two cases and the price is right for me. Please tell me which you like better and why. If you have a better suggestion please let me know.
Antec 300 Illusion $57
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066&cm_re=three_hundred_antec-_-11-129-066-_-Product
NZXT LEXA S LEXS $60 AR
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146060&cm_re=nzxt_lexa-_-11-146-060-_-Product
The Antec 300 is a nice fairly roomy case, it has more than enough space for a 4850, the NZXT is a bit larger and both will have good cooling, so it really comes down to personal preference, and if you are going to use that rebate. If you arent going to use the rebate then i would go for the antec since its significantly cheaper, if you are going to use the rebate then get which ever one you think looks cooler.
