Yesterday I came home from work and all of the parts for my new PC were finally there.
Yay! Being my wife's birthday though, I couldn't just spend all night putting the PC together. 🙁
So later that night I finally got some time to build the PC. I slapped on my anti-static strap and threw everything together as quickly as I could. In the end to get through all of the retail packaging and fit all of those damn little cables onto the mobo it took me three hours. In retrospect, I probably should have taken more time. :\
It all went pretty easily and quickly except for all of those damn little front-panel leads! (AKA the power switch, reset switch, and LEDs and crap, the front-panel firewire and USB leads, and the front-panel audio leads.) The Firewire and USB were, of course, all done in individual pin brackets. Why couldn't we just have a nice standard jack people? Ugh. On no. That'd be too bloody easy. Doing a Firewire cable and two USB cables pin by pin was a royal pain in the arse!
What <i>really</i> ate up a lot of my time though was the front panel audio cable had different labels on the pins than what the manual said and I spent a good half hour just trying to figure out what the hell the manual was trying to tell me to hook up where. In the end I gave up and left the front panel audio cable disconnected from the mobo. I'd have thought that it'd be easy enough to figure out, and after hitting the internet this morning and finding the correction to the instructions it turned out that I was right. But I didn't want to kill anything by being wrong, so that's why in the end I didn't connect it last night. Better safe than sorry.
So anywho, everything assembled, I plug her in, hit the power button ...
and nothing happens.
Oops. Not even the power supply fan spun up. Talk about an anti-climax! (Though I suppose at least it was better than a night ending in smoke.) I didn't even think to leave the case open so that I could see if any internal LEDs lit up, but I doubt that they did.
Getting to be very late at night which at that point my contacts had felt like they dried up an hour ago and my eyes ached like hells fury and my vision was growing fuzzier by the second, I was having little desire to mess with the system any more last night. (And couldn't even see all that well even if I'd felt up to it.)
It occurs to me that I <i>should</i> have taken the time to test the power supply before I had really done much of anything. I just knew that I didn't have the time then and rushed, assuming (hoping) that it'd all work out anyway.
I know that I <i>did</i> connect the little 12v cable to the mobo. I also know that I connected the CPU fan up to the CPU fan header. Heck, I even connected the power supply's fan monitor cable to a fan header on the motherboard just so that I could monitor it. (I don't think I could possibly be more sick of those infernal tiny little cables! I hadn't worked on a fresh mobo in a long time and forgot how annoying those can be, and this project of mine seems to have a very atypical number of them to boot.) I'm pretty sure that I connected everything. And <i>most</i> of the cables are designed in such a way that they can only be connected in one way.
But I still have a few stupid questions just to make sure:
1) If I have the power supply completely disconnected from the motherboard, will its fan spin up if I plug it in and turn it on? (So that I can make sure it's not just a dud power supply.)
2) Black is negative, right? All those damn little cables with tiny little pins, it's possible that I just didn't connect the case's switch to the motherboard correctly (for all that I know the power switch cable could just not be pushed down far enough or have gotten pulled out accidentally), but I also wonder what'd happen if I had switched those little plugs backwards...
3) Would clearing CMOS possibly make any difference if nothing is spinning up at all? I'd think no, but hey, it isn't like it's hard to clear it if it would make a difference.
So anywho, that's my tale. It's kind of sad. I thought that I knew exactly what I was doing, but it turns out that it's been a while and now I'm not quite sure of myself. So please help out an old idiot and his sleep-deprived mind.
Oh, and one final question ... what do I do with all of those little stickers? Normally you'd just put an OEM sticker in the little square indent and be happy. I even ordered the free Newegg one to do just that with. But if I remember my new inventory correctly, I now have one each for Newegg, Antec, Asus, and MSI. (Maybe I even have an 'Intel Inside' one buried somewhere in the retail packaging. I didn't actually look...) I might be wrong on the Asus. It's so hard to remember at the moment. But what do I do with them all?! It's mad I tell you, MAD! Many stickers and just one square!
(Yes, I am that sleep deprived. This is what happens when your brain is trying to shut down but you keep feeding it sugar and caffeine. OEM stickers become an army of angry squares, all vying for my attention and a prominant display. Can't we all just get along?)
"<i>Yeah, if you treat them like equals, it'll only encourage them to think they <b>ARE</b> your equals.</i>" - Thief from <A HREF="http://www.nuklearpower.com/daily.php?date=030603" target="_new">8-Bit Theater</A>
