Hi all!
My external WD Elements SE became unusable after I reboot my pc because it was not accepting some files transfers.
It's stuck on RAW format and I can't do nothing with it. Sometimes the Win Explorer recognizes it, others doesn't. I went through several tips on the internet and I will write what I have done so far.
1- The Data Lifeguard diagnostic shows it with a Raw Read Error Rate.
2- Used the HDD Low level Format tool and it showed some "Format Error occurred at offset" the entire format.
3- The HDD Regenerator shows this message: "Master Boot Record of this hard drive is damaged!"
4- The diskpart shows this message after my attempt to converting it " DiskPart has encountered an error: The request failed due to a fatal device hardware error. See the System Event Log for more information."
I don't know what I should do now. Is possible to make this hdd work again or is it dead?
Thanks!
Thanks!
