Please help
Tony
1,944
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hi
My laptop crashed recently and I was unable to get into
Windows xp. I was advised to do a patch repair of winxp.
The problem is that the laptop stops on the first screen.
On switching on all tha appears is this
American mega trends Released 10/30/2001
AMIBIOS ( c ) 2000 American Megatrends Inc
BIOS VER 2.06
MS570 KBC Version: 1.16
Intel Celeron T , 1 Ghz
Checking NVRAM
253952KB OK
ICS9248-146 Inside
WAIT . . .
_
The cursor just continues flashing at this point and I
cannot go further - Ctrl, Alt, Del simply restarts the
same process again and F8 and Esc do nothing
Please help!! I have lots of valuable information
It would appear that you have a more fundamental problem on your PC.
If it were simply the Hard Disk that has an error, then you would get a message 'cannot find system disk' or somtheing to that effect.
Can you access BIOS. Not stating in your post the make, model etc. makes it difficult for others to assist.
If so then maybe you can get some way along to reconfiguring the Laptop and getting it to boot up to CD ROM for a Windows Reinstall.
If you find that the Laptop isn't going to play ball; consider that your most valuable component of the Laptop is YOUR data on the Hard Disk..then you should get assistance if you are not experienced or competent to do this step.. Remove the Hard Disk Drive and connect it into a Desktop PC, Tandy and other electronic shops have Laptop IDE to PC IDE connector cables / plugs.
Backup all your data to Hard Drive and then Burn onto CD.
Send the Laptop off to be fixed or buried as required. I suggest the latter because a new Toshiba 2.4Mhz Celeron with 30Gb HDD, 256 Mb Memory, DVD, Ethernet, Wireless Access, Modem etc. cost less than US$ 1,000 today!
did ur laptop come with a repair/bootable cd? try using that to boot and see
if u can use the repair options of the windows installation. see if this
works.
"Tony" <anonymous@discussions.microsoft.com> wrote in message
news:16c8201c4208a$f0372ce0$a001280a@phx.gbl...
> Hi
> BIOS VER 2.06
> Checking NVRAM
> 253952KB OK
> ICS9248-146 Inside
> WAIT . . .
> _
