PLEASE HELP!!
redlock66
22
So I am thinking about buying a graphics card to upgrade my computer, but i have no idea if the parts will work with each other. I'm thinking about upgrading my ATI Radeon 4200 HD to a Radeon 6850 HD.
my specifications are
OS: Win 7 Home Premium
Processor: AMD Athlon(tm) II X2 245 Processor (2 CPUs), ~2.9GHz
RAM: 4GB
Direct X:11
Graphics card: ATI Radeon HD 4200
(dont know if its important or not)
Chip type: ATI deisplay adapter (0x9710)
DAC Type: Internal DAC(400MHz)
Approx. total memory: 1916 MB
Will My computer be able to use the ATI radeon HD 6850 with out bottle necking it? If it does bottle neck it, what is the highest graphics card i can upgrade it to without bottle necking it?
OH! and I would like to play anything really on low settings at least. im not into the big showy graphics but its nice to be able to play on high settings. im mostly playing first person/Third person shooters, but sometimes real time stratagy.
My windows 7 is a 64-bit computer
my range is around $130-$160
Does this help? 😀
This is perhaps one card that you could go with. It has a high amount of ram which will be more then adequate for you. You wouldn't be playing games on low which I know you are not asking for anything beyond low but to have a card that will only allow you to play on low is unacceptable it means your system can not handle the game in my eyes. Much cheaper I think you are looking at 1 gb 7850's and 1 gigabyte 650ti, 650 non ti's.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130840&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566&SID=
@ASH
Yes would you also tell us the resolution of your screen I'll take another picture to illustrate this for you...
Okay I'm sure the community can help.
1.So firstly let me ask you what are you playing or what would you like to play.
2. What settings would you consider acceptable.
3. How much money are you looking to spend
4. Are you using a 32 bit OS or a 64 bit. Right Click on my computer and go to properties.
Does this help? 😀
@ASH
And you are positive that this card will work? without me bottle necking the card? i didnt buy this as a gaming computer to begin with so it has a normal motherboard, integrated graphics and a regular proccessor. are you POSITIVE?
Well after looking around and trying to ask Dell what your motherboard is I have come to the conclusion that you are using a pci-e 2.0 board. A 7770 requires a minimum of 450 watts a 7750 would require a 400 watt power supply and that graphic card only uses the power of the slot so you should be okay with that however I would still go out and replace your power supply if you can.
oh... are those power supplies that exspensive? like $150 and up? wait nvm i think i found a 500 wt power supply for $49. is that good? and did you mean that the 650 will run on my cpu without minimum power supply or is it manditory i get a bigger supply before ordering?
