easiest way is to get a fan controller.
other way to put a pencil in your fan and that will reduce the fan speed if not stop it .
but yeah give us a bit more information. why would you want to reduce fan speed? the fan goes at a certain speed for a reason.
Uhm it's a shuttle, small form factor? I'm pretty sure if you unplugged it the whole case would overheat. The CPU fan is the only fan in there! (maybe GPU)
Forgive me for being serious for a moment, but I thought I'd share this.
I think your options are limited with a Northwood Pentium, but I have my fan set to adjust speed based on cpu temp, and I have my Opteron set to drop it's voltage to 1.1 volts, and drops the multiplier to 4x (from 9x) when idle.
At idle speeds, with reasonably cool room temps, the cpu fan shuts off occasionally, then comes on for a few spins and goes off again.
Btw, I use this box as a DVR, and it stays at 1.1v/4x and idle temps while recording, and when I use it to play games it restores the voltage and overclocks.
