Question pls help, freeeeze :( :(
DeathHadArrived
177
5
595
do i need alcohol?? cant i just wipe it with a tissue or a cloth?
its a relatively new thermal paste like 2 weeks old
you can use 70% alcohol or more. Anything less could have too much liquid. Also pro tip: Wait around 5 minutes for the alcohol to dry once you cleaned the top of the CPU. I suggest you buy 70% alcohol because of its versatility from cuts to cleaning and that it is cheap.
Oct 20, 2020
80
bruh pc was at 75c and it froze. wtf
Oct 20, 2020
80
did you redo the thermal before testing?
omg why do i even need to change thermal paste after removing cooler and keeping it back , is 75-80c that hot to make the pc freeze and i have to shut it down from the case. worst thing is what if i get new thermal paste and i change it, what if it still does the same.
:( man this sucks pls try to help me
rgd1101
we are trying, but you keep doing your own thing and not listening, why are you asking for help if you don't listen?
Oct 20, 2020
80
ok i have access to hy510 thermal paste branded "halnziye". thats the only thermal paste i can buy. and i dont have alcohol, i dont think so i need as the thermla paste is like 2 weeks old and is still kind of fluid and easy to wipe off, i guess
