Question Pls help
Mar 7, 2019
35
I got a gpu which is an
XFX r7700 ghost series
And a psu that is an ace 500w output but doesn't have a 6 pin connecter for my graphics card I ordered an adapter that has 2 molex inserts and 1 6 pin exit to plug into a gpu but i don't k ow how many molex cable do I need to plug into the adapter 1 or 2 a simple answer would be greatly appreciated thanks :)
stop spamming the forum
I assume that your psu is powerful enough to power your system.
while it is never recommended to use those molex adapters to connect a gpu it depends on what gpu you are trying to Power up it should be fine for a low power one
But generally it is safer to connect them on different cables
yh ok thanks for the help Im just very eager to test out my gpu but I have to wait then till sat im not gonna take the risk of anything buring down or something
Which PSU do you actually have ? List the exact Model number/brand. Are you trying to power up the motherboard, or some other component, like the GPU ? MOLEX cables are usually not recommended, though first you need to list your requirements, and provide more details.
