Hello, I was upgrading my current build so i could max out diablo 3 at 1920x1080. I would like to start my build from scratch but didnt want to spend the money right now.
So I upgraded the PSU/GPU thinking that would work until i could rebuild. After doing the upgrade/clean install of drivers, the fps is nice and high in the cities/small fights. but as soon as i hit a big fight/lots of effects ill slow to a crawling 15-20 fps until its done. clearly thats what i was trying to fix.
The GPU i purchased is a XFX 6950 2gb ( http://www.newegg.com/Product/Product.aspx?Item=N82E16814150549 )
The psu is a OCZ Fatal1ty 750w modular ( http://www.newegg.com/Product/Product.aspx?Item=N82E16817341041 )
I figured i would go much higher than what i needed for D3, just in case. and then later reuse the PSU/GPU in the new build.
Now that im still having the issues, im wondering if i need to rebuild, or if just a simple processor upgrade(if thats my issue) could hold me over until i can afford a complete rebuild with an i5-2550k.
Possibly a Phenom II x4 965? http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
Current build.
AMD Phenom 9650 x4 2.3ghz
Gigabyte GA-MA785GM-US2H mobo
2x2gb ddr2 ram 800mhz
and a 1.5TB 5400rpm hdd(i think)
any help would be greatly appreciated.
Current build.
