Power Button does not work NZXT S340 Elite
ThHugo60000
21
I have recently purchased that parts for my first build. I followed many videos and took my time building it however when I finally hit the power button to see if it worked nothing happens.....yikes. I'm thinking it might have to do with one of the cables that comes pre-installed in the case I could very possibly have something plugged in wrong. Any recommendations would help before I need to take to a store to have someone look at it.
Regarding the placement of stand-offs.
If they came pre-installed, you MIGHT have one (or more)in the wrong place. From what you say, you did not verify that before installing.
The only way to be sure, unfortunately, is to remove the mobo from the case and inspect carefully. Ideally there ought to be a stand-off under each mounting hole in the mobo. But MOST importantly, make sure there are NO stand-offs any place where there is NOT a mobo mounting hole.
There are a few cases that come with a special stand-off for certain mobos. Normal stand-offs have a threaded hole in the top for the screw through the mobo mounting hole. But sometimes the case will include an odd stand-off with an insulating rubber top on it. That can be used under...
Two ideas to check.
1. Is the main power switch mounted on the back of the PSU turned on?
2. A common form of error on new builds, especially first ones, is with stand-offs. They are those little metal spacers that screw into the back mounting panel of your case so that you can fasten down your mobo to them using screws through holes in the mobo. Often they come pre-installed in your mobo, but MAYBE they were not installed at all and you have to do that yourself. Anyway, the most important factor with them is that there must NOT be any stand-off under your mobo where there is NOT a hole in the mobo for a mounting screw. Any stand-off under the mono in the wrong location can cause a short to Ground from traces on the bottom of the mobo. This can cause a total failure to start up.
If you need more detailed info, post back here.
I have the NZXT S340 Elite case I am pretty sure it came with the spacers pre-installed but I am not sure... I just triple checked to make sure everything was plugged in correctly and it still is not working any other ideas??
I have no idea how to start it from the motherboard
[PCPartPicker part list](https://pcpartpicker.com/list/Q8Xtyf) / [Price breakdown by merchant](https://pcpartpicker.com/list/Q8Xtyf/by_merchant/)
Type|Item|Price
**CPU** | [Intel - Core i5-7600K 3.8GHz Quad-Core Processor](https://pcpartpicker.com/product/dQM323/intel-core-i5-7600k-38ghz-quad-core-processor-bx80677i57600k) | $228.79 @ SuperBiiz
**CPU Cooler** | [CRYORIG - H7 49.0 CFM CPU Cooler](https://pcpartpicker.com/product/93Crxr/cryorig-cpu-cooler-h7) | $34.89 @ OutletPC
**Motherboard** | [MSI - Z270 TOMAHAWK ATX LGA1151 Motherboard](https://pcpartpicker.com/product/vXdFf7/msi-z270-tomahawk-atx-lga1151-motherboard-z270-tomahawk) | $129.89 @ OutletPC
**Memory** | [G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory](https://pcpartpicker.com/product/Nqp323/gskill-memory-f43200c16d16gvrb) | $133.88 @ OutletPC
**Storage** | [PNY - CS1311 240GB 2.5" Solid State Drive](https://pcpartpicker.com/product/7v38TW/pny-internal-hard-drive-ssd7cs1311240rb) | $89.99 @ B&H
**Storage** | [Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive](https://pcpartpicker.com/product/MwW9TW/western-digital-internal-hard-drive-wd10ezex) | $48.44 @ OutletPC
**Video Card** | [MSI - GeForce GTX 1070 8GB Video Card](https://pcpartpicker.com/product/fKp323/msi-geforce-gtx-1070-8gb-video-card-gtx-1070-gaming-x-8g) | $404.40 @ B&H
**Case** | [NZXT - S340 Elite (Black/Red) ATX Mid Tower Case](https://pcpartpicker.com/product/K8QRsY/nzxt-ca-s340w-b4-atx-mid-tower-case-ca-s340w-b4) | $88.99 @ SuperBiiz
**Power Supply** | [EVGA - SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply](https://pcpartpicker.com/product/qYTrxr/evga-power-supply-220g20550y1) | $69.89 @ OutletPC
**Case Fan** | [Corsair - ML140 Pro LED 97.0 CFM 140mm Fan](https://pcpartpicker.com/product/sYNypg/corsair-co-9050047-ww-970-cfm-140mm-fan-co-9050047-ww) | $29.98 @ OutletPC
| *Prices include shipping, taxes, rebates, and discounts* |
| Total (before mail-in rebates) | $1314.12
| Mail-in rebates | -$25.00
| **Total** | **$1289.12**
| Generated by [PCPartPicker](http://pcpartpicker.com) 2017-06-04 14:21 EDT-0400 |
There are a few cases that come with a special stand-off for certain mobos. Normal stand-offs have a threaded hole in the top for the screw through the mobo mounting hole. But sometimes the case will include an odd stand-off with an insulating rubber top on it. That can be used under the mob where there is NOT a mounting hole, and some mobos are like that near the centre. But that is the ONLY situation when a stand-off can be in the "wrong" location.
