I just assembled my new Unraid build which is as follows:
case: fractal node 304
mobo: MSI MPG B560I
CPU: Intel Core i5-10600K
Memory: https://www.amazon.com/gp/product/B08HLYSHJC/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
PSU: https://www.newegg.com/super-flower-leadex-iii-sf-550f14hg-550w/p/1HU-024C-00008
CPU Cooler: Noctua NH-U14S, Premium CPU Cooler with NF-A15 140mm Fan
I just got everything put together and put in my 3 HDDs and my unraid USB drive. When I tun on the system, it boots into the BIOS. It seems to detect everything correctly - it shows the correct CPU and memory. It see the hard drives and the USB stick. I set the boot order to boot from the USB stick. but after I reboot, it just keeps booting into the bios.
If I unplug the power cord from the PSU, wait a moment and then plug it back in and boot back up it usually spins up for a second and then shuts down - then spins back up and says "All settings were reset to default values"
Press F1 to Run SETUP
Press F2 to Continue
and all the bios setting I have made have been reset to default.
what could be wrong? I have not built a pc for several years so its possible I may have screwed something up
any advice would be greatly appreciated!
mobo: MSI MPG B560I
