Hello,
I recently built my first PC and everything seemed to be working. But today I ran into a problem I can't find a solution for on the internet.
Whenever I shut my PC down, my Power LED on my case shuts off and then less then a second later the LED will light up again (my PC does not turn back on or sth like that).
Sometimes the LED will start by flickering a bit at first, but it will always go away after a few seconds.
Also weird: if I completely shut my PC down by turning the power supply off manually and then turning it back on - with the built-in switch - then the Power LED will remain off.
Now I am not sure if I should be worried about it or not, but my PC did not do this the last few weeks.
What I've tried so far:
I'd super grateful for any help or advice,
Lukas
My System:
CPU: Ryzen 7 3700X
Motherboard: ASROCK B450 Steel Legend ATX
GPU: GTX 1060 6G (ASUS Strix) - just a placeholder for my other GPU that required some fixing
PSU: Sharkoon SilentStorm Coll Zero 650W
RAM: Corsair Vengeance LPX 3200 MHz 16 GB (2x 8gb sticks) CL16
HDD/SSD: 2 SATA SSD + 2 SATA HDD
Case: bequiet! Pure Base 500 (tempered glass)
- Turned fast boot in windows off
- Checked if any cables were shorting to my case; none did
- Removed the Front Panel Headers for the Power LED - LED turned off - and pluged them back in - LED immediately turned back on.
Lukas
My System:
CPU: Ryzen 7 3700X
