Power Options
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics,microsoft.public.windowsxp.setup_deployment (More info?)
I desire to temporarily change the "Turn off monitor:" option to "Never."
But when I do this, it has no effect. The monitor turns off after 20
minutes.
I am having trouble installting a very large program to my computer that
takes a couple of hours to install, and I want to set the monitor to not
turn off since that might be causing an error.
Is there something fancy I could do to make my computer do my bidding, like
change a registry value?
Hi,
Check power management settings in the system BIOS.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"Mister Scary" <danielnewhouse@bellsouth.net> wrote in message
news:%23T45D1%23vEHA.728@TK2MSFTNGP11.phx.gbl...
> minutes.
> like
news:#T45D1#vEHA.728@TK2MSFTNGP11.phx.gbl:
> "Never." But when I do this, it has no effect. The monitor turns off
> after 20 minutes.
> that takes a couple of hours to install, and I want to set the monitor
> to not turn off since that might be causing an error.
> like change a registry value?
just curious, what program would take a couple of hours to install ?
DanS
A big one that is being downloaded and run without first saving it to
a file comes to mind. Another one even when it's installed off a
network drop here at my company is something called CATIA. It can take
a long time especially if I'm uninstalling the previous version as
part of the install.
"DanS" <t.h.i.s.n.t.h.a.t@a.d.e.l.p.h.i.a..n.e.t> wrote in message
news:Xns9594A4A481CFFidispcom@216.196.97.142...
off
> > after 20 minutes.
computer
monitor
bidding,
> DanS
Hi, Mister Scary, did you check if it is not the Screensaver turning off
your monitor. That happened on my Dell and after increasing the time on the
Display>Screensaver to 600 minutes, I have no more problems.
Gerry
> minutes.
> like
