So, the issue is that PC turn on after 4pin from 20+4pin connector plugs in-out of the motherboard. It should be done for 4-5 times to turn pc on.
Whats wrong with m.b. or p.s.u. ??
Like you said maybe the MB or PSU, because 1) the PSU is very bad. The 600W will not tell the whole story about the PSU, only the brand/model will tell. Check the PSU recommendations list: http://johnnylucky.org/power-supplies/psu-recommendations.html 2) The MB may have problem, it is old. So try other good brand PSU to boot the PC.
All right then, can someone explain to me how it technically possible to PC to switch itself on after I puting the 4pin poer supply plug to another 20pins in the main power connector ?
