S shadowd94 Honorable Apr 25, 2012 20 0 10,510 May 20, 2012 #1 Hi, will a 650 power supply work with this build? http://pcpartpicker.com/p/8wkq
Rugger Splendid Jan 11, 2005 6,707 0 26,160 May 20, 2012 #2 A good 500W PSU would work with that build. Upvote 0 Downvote
refillable Splendid Nov 15, 2011 5,814 201 28,240 May 20, 2012 #3 A really easy question to answer: YES!!! Upvote 0 Downvote
coper210 Distinguished Nov 19, 2011 341 1 18,810 May 20, 2012 #4 just put in your specs and you will find the right amount of wattage you need for your power supply http://images10.newegg.com/BizIntell/tool/psucalc/index.html Upvote 0 Downvote
Rugger Splendid Jan 11, 2005 6,707 0 26,160 May 20, 2012 #5 nVidia specifies that a system with a single GTX 670 requires a 500W PSU with 35A on the 12V rails and two 75W 6-pin PCIe power connectors. Stick with a good quality PSU. A great deal on a great PSU right now is the Seasonic M12II-520W: http://www.newegg.com/Product/Product.aspx?Item=N82E16817151093 I own this PSU and love it; 40A on the 12V rail, 5yr warranty, quiet, rock solid rails. Upvote 0 Downvote
