Question Power Toys Run
93boba
122
The best feature in my opinion given by PowerToys is the "Run" feature similar to the spotlight on MacOS. I want it to always run on my desktop without me needing to press each time shortcut to make it pop up. Is there a way to just make it always be there, some sort of a widget?
Yeah, thats one of the reasons I never used it, I couldn't make it always show on the desktop. Microsoft Edge had a floating search on your desktop on windows 10 that worked great, but they abandon it on Windows 11, go figure, make something useful then remove it...
Are you able to use Task Manager > Startup?
Powertoys start on the boot thats not an issue... I just want the "spotlight" feature to be always on desktop
Yeah... I hid desktop icons and floating search would fit in perfectly. Having to press shortcut each time is a real pain
Are you using Alt+Space to open PowerToys Run?
And then working with the "Start typing ..." Window always visible somewhere?
You could use Powershell's SendKeys to create a simple script and have that script launched at startup or via Task Scheduler.
"Are you using Alt+Space to open PowerToys Run?
And then working with the "Start typing ..." Window always visible somewhere?" - Yeah
That's an interesting approach but I have no clue how to achieve that... Wherever I use alt+space search widget comes always on top and I don't want it to be always on top. And if I click anywhere else besides the widget it shuts down immediately. Are you sure that the script will do the job? Thanks man
By "on top" you mean physically located about 1/4 of the way down from the top of the monitor and centered there?
(That is where my "Start typing...." appears.)
Where, with the premise that once scripted, the "Start typing... " window would always open in th same place.
Yes Powershell can set window locations. I found a couple of scripts with supporting functions to do such things.
Doable but likely cumbersome to get it all working together just for the sake of avoiding Alt+Space.
Try typing "PowerToys" the lower left corner Search (oval) box.
A PowerToys Settings "General Window" should open thereafter.
Not something that I have worked with but you may find a setting that is acceptable with respect to the location and nature of the "Start typing" box.
Also this link:
https://learn.microsoft.com/en-us/windows/powertoys/run
Undersettings there is a reference to creatin an Activation shortcut.
Specifically, from the link: "Define the keyboard shortcut to show/hide PowerToys Run"
Another way could be key remapping:
https://learn.microsoft.com/en-us/windows/powertoys/keyboard-manager
The end objective being that you explore the options and determine if any of those options are viable and acceptable.
Alt + Space may not seem so bad afterall....
Also this link:
Always on top = allows an app to display content over another app. I'll look into it, thanks. It's weird that they didn't include widget option tbh
