Powersuply problems?
maldik
24
Hello!
I have some issues with my computer, and i'm starting to think it's the psu. When i run prime95 and look at at the cpu-z i have quite jumpy voltage (+-0.015v or so), and problems in getting stabil clocks on my cpu. It even fails after a while (30 min) with the asus auto overclock when temps are under 50C. If i run furmark i also get problems with the burn test before any critical temp(system shutdown).
system:
2600k (watercooled)
2x GTX 560 ti
Asus p8z68-V
8 gb Corsair XMS3 1866MHz
Thermaltake Toughpower 750W (from Q1 2007)
I'm not sure if it's the cpu, or the fact that i was cheep in not buying a rog motherboard though 😛 But this motherboard should work.
When i try high clocks like 5ghz + on cpu, it can be stabil for over and hour before i get blue screen :/
would be great with some help here :)
