Pre-Order Asus 31.5" 4K IGZO Monitor for $3500
The Sharp PN-K321 31.5"" 4K Ultra HD monitor is available today and is already being used by many technology companies including AMD, Microsoft, BlackMagic Design and many others.
You do know that the ASUS uses a SHARP panel...
I did 2560x1600 just fine on one card.
I am not able to confirm or deny that information. What I can confirm is that the Sharp model is available and shipping.
You can drive the Sharp PN-K321 at 3,840x2,160 on single AMD or nVideo compatible video card. If trying to go to 60 fps, you'll need to use MST mode. 30 fps is no problem without using MST mode.
grrr.... replies are loopy again...
Yup, I knew it was possible. As for SHARP being the panel manufacturer, it says it in the article I think, and IGZO is SHARP proprietary tech.
IGZO is not a Sharp proprietary technology. Sharp is the first manufacturer to successfully mass produce and manufacturer it.
