I idontknowwhattosay Sep 1, 2021 3 0 10 Sep 1, 2021 #1 I'd like to swap out the motherboard. Which motherboard is recommended? Preferably with an Am4 socket type.
Solution kurdtnz Sep 2, 2021 One of the B550 boards is probably your best bet. Just make sure your RAM will be compatible in the swap.
kurdtnz Honorable Feb 24, 2020 2,223 370 12,640 Sep 1, 2021 #2 What is the rest of your PC specs? Upvote 0 Downvote
I idontknowwhattosay Sep 1, 2021 3 0 10 Sep 1, 2021 #3 i7-9700 Rtx 2060 32gb Ram 1 m.2 ssd 4 ddr4 slots Last edited: Sep 2, 2021 Upvote 0 Downvote
kurdtnz Honorable Feb 24, 2020 2,223 370 12,640 Sep 1, 2021 #4 You have an intel cpu but are asking for an AMD motherboard? Upvote 0 Downvote
I idontknowwhattosay Sep 1, 2021 3 0 10 Sep 2, 2021 #5 I currently have an intel CPU installed into this old motherboard yes, I really just wanna replace it with one that that fits a 5600x. I don't have the patience for a new build. The model is M/B 1151.B36H4-AD(1.1) Part number DB.E1111.001 Upvote 0 Downvote
kurdtnz Honorable Feb 24, 2020 2,223 370 12,640 Sep 2, 2021 Solution #6 One of the B550 boards is probably your best bet. Just make sure your RAM will be compatible in the swap. Upvote 0 Downvote Solution
