Printer Quality
G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
Ive been having a problem with my cannon s600 printer, the problem
starts when i go to print a document and all i get out is the words
faded or only half the words printed out and the quality isnt that
good, iv tried all the common problems like cleaning the cartridge and
aligning the printer but nothing seems to be working, even when i print
the document in best quality it improves the quality but not by much,
The cartridge is a new one so i dont think this is the problem,
Any help would be greatly appreciated
Regards,
Colm
Have you tried...
Re-installing the printer drivers?
Checking the connections? USB or printer cable?
And are you using Canon inks?
Its installed by a ubs cable so theres no need for a driver, and yes
bought the cannon inks new recently,
Thanx for ur reply,
Regards
