I've been having trouble getting my Plextor PX-M2 Series PX-128M2S running at its rated speed. It is a 128GB sata III SSD. Its rated to run at 420mb/s read and 210mb/s write. When I first built the PC(built in late august of last 2011) it was really slow but I had to change it from ide to achi in the bios. After I did that it was around 375 read and 180 write. Then a few months later I notice that my boot time went from 21 seconds to 32 so I ran a benchmark and it was around 325 read and 120 write. I decide to do a fresh install of Windows 7 not only because of the SSD but also because I like to have a fresh every few months because Windows likes to just take up space the longer you use it. I wiped the SSD and then made sure everything was right in the bios(its in achi mode), made sure the cables are right and yes I'm using a sata III cable and the motherboard supports sata III. Then I did the fresh install, did some optimization and ran AS SSD Benchmark. Now its 320 read and 80 write. Not sure whats wrong with it. Some weird things I did notice were that in the bios it says the drive is ide, same with my optical drive which is also sata. Windows recognizes that it is a sata drive so I'm not sure what the bios is doing. Also there is a option in the bios to either run that sata ports at sata II or sata III speed or auto. I have it on auto because the optical drive is sata II but should I change it? can anyone help me get my drive running at its rated speed?
Motherboard is a ASUS M4A87TD/USB3 AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
