Hello there. I'm new here, so, thanks in advance for any help you can give me.
I am having a small problem but that bugs me quite a bit. If I completely power off the computer, when I am trying to turn it on, it won't turn on the first time I press the power button, instead the front Led panel of the rig witll turn on for a second and then turn off immediately, just like when you unplug the PC and press the power button to discharge the remaining electricity. Then if I press the button again it will turn on normally. And then if I put the PC on rest mode, if I try to wake it up right away it will, but after a couple of minutes or maybe an hour or so, if I try to wake it by clicking on the mouse or pressing a key, the same thing will happen, the front LED will flash and the computer won't wake. I have to press the power button after that to wake it properly. It's the only problem I'm having but it seems oddly specific.
I don't know if my specs will help with this but here they are anyway:
AMD Ryzen 7 3700X 8-Core 3.59 GHz,
32 GB RAM
Cougar CMX 850 power supply
Cooler Master Masterliquid Lite 240
GPU NVidia RTX 2080 SUPER
ASRock B450 Steel Legend Motherboard
All of it inside a Cougar case.
Thanks!
32 GB RAM
Thanks!
