Ok.
So everything seems to work at least until I install windows 7. I've tried installing windows 7 multiple times and even re-downloading, burning, new copies on my pc and my friends.
The end result is always the same. Once installation is finished and it goes for that last restart, it eventually freezes on the loading screen.
Now I have been able to install it and make the pc boot up. But it only works when I remove one of the 2 sticks of RAM?It doesn't work when I add the other stick of ram.
http://pcpartpicker.com/p/o50h
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
So those 2 links contain everything inside this build with the exception of the video card that I have yet to receive.
Any suggestions on what to try?
Bios is up to date with the latest version too.
Thanks.
Edit: PC also seems to restart when I click shutdown from the start menu.
Thanks.
