P paulius.kvasnickis Prominent Dec 20, 2018 19 0 510 Sep 2, 2020 #1 Hello. I bought PHANTEKS ECLIPSE P350X Case. And my motherboard doesn't have D-RGB connector (3 PIN) for the RGB of the case . How can I make case RGB work? Is there a connector straight to PSU or something like that? Thanks for help
Solution hang-the-9 Sep 2, 2020 There are buttons for rgb controls on the case. If you read the manual it will tell you how to use it.
hang-the-9 Titan Mar 25, 2010 60,368 1,081 152,940 Sep 2, 2020 Solution #2 There are buttons for rgb controls on the case. If you read the manual it will tell you how to use it. Upvote 0 Downvote Solution
