Problem with Control+Alt+Del
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
Hi, i'm having a problem with my computer, when i press control+alt+del,
nothing happens, i don't know what's going on but the system doesn't do
anything. Also, when i enter in safe mode it does work so i'm guessing is
some sort of problem in my normal mode configuration or maybe some virus,
anybody knows anything about it or may have a solution for the problem??.
By the way i'm running windows xp home edition with the service pack 2.
I've had bad keybopards do that,; beyond that, one of the experts will have
a better solution!
For evil to prosper requires only that good men remain silent!
"Alex T" <Alex T@discussions.microsoft.com> wrote in message
news:1993B4C8-0F08-4CB2-A72A-2BD6176BAE67@microsoft.com...
I know is not the keyboard because when i go on in safe mode i press the same
keys and it does work.
> a better solution!
> the same keys and it does work.
>> will have a better solution!
>> > control+alt+del, nothing happens, i don't know what's going on but
>> > the system doesn't do anything. Also, when i enter in safe mode it
>> > does work so i'm guessing is some sort of problem in my normal mode
>> > configuration or maybe some virus, anybody knows anything about it
>> > pack 2.
The best way to find out if your computer has a virus is by doing a scan
with your installed antivirus in Safe Mode. Your installed av should be
a current version, not earlier than 2004, and your virus definitions
subscription should be active and the definitions up-to-date. Here are
some general malware removal steps, including what to do if you do not
have a full-featured antivirus installed:
http://www.elephantboycomputers.com/page2.html#Removing_Malware
Malke
Elephant Boy Computers
"Don't Panic!"
MS-MVP Windows - Shell/User
