Question Problem with i7 12700k
Nighthawk117
Upstanding
Sep 27, 2021
311
78
290
5
djazu1984
16
Are you talking about the silver bit's on it? If so that's normal for Alder Lake, a cooler that was too tight would warp the substrate but yours's looks fine to me. As for your 4x on the GPU, need to know the board model really.
  1. Is the GPU in the top slot?
  2. Does your motherboard have multiple full length slots and if so did you populate any of them?
The drawings you speak of:
https://images.hothardware.com/contentimages/newsitem/56396/content/small_intel_core_i9-12900K_backside.jpg
Normal.
Yes gpu on top, other ports as well only 4x speed.Maybe the mb faulty than, the drawings seem to be the same as on the 12900k.
Nighthawk117
Upstanding
Sep 27, 2021
311
78
290
5
Yes I think your CPU is perfectly fine. When you say the other ports are 4x what do you mean. Depending on the board configuration and how the slots are wired up, if you use any of the other full length slots it will reduce the PCI-E lanes to the GPU.
Zerk2012
Ambassador
Hello ,
Could somebody help me please?
My gpu us running only st 4x speed instead of 16x.
I ask myself if the cooler damaged the cpu/ was too tight? Check the photo please.
https://photos.app.goo.gl/bKCAqAjtFEkTG44U6
At a specific angle can i see some "drawings " on it.
And here is everything fine:
https://photos.app.goo.gl/pKjd7F6MRVdz1fDg8
The cooler is bequiet darkrock 4 with the lga 1700 set.
I appreciate your opinions.
How do you know X4 speed post a screen shot.
Zerk2012
Ambassador
Ive checked with gpuz after ive notice a huge fps drops in games. I made bunch of other tests passmark etc.. CPU was ok but gpu benchamark very poor
Was that with something stressing the GPU when you checked GPUZ?
You can look to the right of where it shows it and their a blue ? Click on the ? and it will run a short test and see if it changes during that.
djazu1984
16
Yes i have made the gpuz render test as well and the speed didnt change
