Archived from groups: microsoft.public.windowsxp.games (
More info?)
"Liz" <Liz@discussions.microsoft.com> wrote in message news:23428E99-DD66-4B1F-80F4-66D05A885EDC@microsoft.com...
|I have been playing this for months and suddenly I am getting " Out of Scan"
| message on my flat screen?? Help please !
| technology challenged
There are three things you can do to solve the "Out of Range" error.
1. Change the video settings of the game:
Choose a low setting such as: 800x600 @ 65 Hertz (75 CRT monitors)
If you can't change the setting in the game, save a copy of the game's
.ini file if it has one, and edit it to make the change if you are comfortable
enough, otherwise see if you can add a -safemode switch to the shortcut
for the game. Such instructions are usually listed at the game's support
site, or in the readme file in the game's directory or on the game CD.
For more info:
http://support.microsoft.com/default.aspx?scid=kb;en-us;315614
2. Set up your monitor and update it's drivers:
Right click on the Windows Desktop where there are no icons.
Click Properties in the pop-up menu.
Click the Settings tab, then the Advanced button.
Click the Monitor tab.
Make sure that your specific monitor model is listed under Monitor
Type. If it is listed as a Standard Monitor, PNP Monitor or something
similar, check with the monitor manufacturer for the proper drivers
These drivers are usually available on the manufacturer's web site,
or search for them at: www.driverguide.com or www.downloads.com
3. Make sure that your monitor is capable of the Screen Refresh Rate:
Your monitor documentation should list the appropriate settings, or
check the box in the Monitor tab to "Hide modes" it can't display.
You can also set a max refresh rate for all games directly in DirectX.
Click Start, Click Run, type: dxdiag press [ENTER]
click the More Info tab, click "Override...", and enter the override value.
4. Click the Restore Defaults buttons in Control Panel / Display / Advanced.
For example, if you have a GeForce, click the GeForce Tab, and then
go through each item in the left tray list to click "Restore Defaults". The
most important item to uncheck is Display Timing / Enable Doublescan.
5. Try updating your Video drivers using the instructions at:
http://mvps.org/nibblesnbits/Video.html#drivers
Cheers, Windows XP MVP Shell / User
Jimmy S.
http://mvp.support.microsoft.com
Game FAQs:
;gms]http://support.microsoft.com/default.aspx?scid=FH;[LN];gms
Visit my Zone.com / Gaming Helpsite:
http://nibblesnbits.tk or Call / Contact
MS Support at:
http://support.microsoft.com/default.aspx?scid=sz;en-us;top
My advice is donated "AS IS" without warranty; nor do I confer any rights.
_________________________________________________________
