problem with music system
Aakash_3
Commendable
May 31, 2016
Hi,
I want to ask something
My problem is that the wire which is coming from amp & is connected to Bass Tube touched each other due to which a loud humming sound has started coming out from the speakers when engine starts its working fine when engine is off.
Can you tell what is the problem with my music system
Hello,
This is Car Audio right? If yes... the problem may comes from your power supply (dynamo)! You should check it. Check also your cables
