Hey all, thanks in advance for the great community opinions that yall give
I'm in dire need of some advice/help at the moment.
My friends computer (that I am trying to fix), is an older sckt 775 system just ran into problems today. After turning it on one day it just wouldn't turn on, or died after boot (during windows load) and then turned off. As my friend persisted in pressing, jamming, and holding the power switch on his case it eventually stopped going as far as the previous attempt (in terms of how far along the comp had turned on) and stopped turning on at all, which is what is going on now.
Now initially I had thought the switch on the case had become loose, however I tried jump starting the comp by shorting the power switch pins on the board but its not turning on. The green LED on the mobo is ON, which means the powersupply is connected and working but after that, nothing. No fans start spinning, nothing.
Any ideas what could be wrong? Since the light is on, on the mobo, that should mean the board and ps are working right? What else could it possibly be?
Any ideas, please,
thanks in advance!!!
Any ideas, please,
