Question problem with sound
.valkyrie.
462
7
10,795
hi, i removed windows 11 Tpm limitations on 6th gen and installed it this morning.
unfortunately i cant use headphone connected to back panel on green port. it wont work...
i used 3Dp and downloaded latest version of realtech audio driver, still not functioning.
Asus website have only driver for windows 10. while my Windows is 11.
should i assume the Sound card is broken?
p.s: just bought this MOBO 2nd had this week. its asus B250 mining expert.
Lutfij
This won't lead you to much benefit in the long run, it's more of a stop gap solution and not a genuine solution.
You should still be able to install drivers, Right click installer>Run as Administrator.
FYI, buying a motherboard or any component that was used for mining isn't exactly a smart move. What BIOS version are you on for your motherboard?
You should download the latest driver for your audio chip from here;
and install in an elevated command.
Where did you source the installer for the OS?
