have just decided to re-install windows XP to my computer and hence have put in the bootable XP disc, got to the 'Windows XP professional setup' screen where both my hard drives are listed.
I want to install XP to my existing C: drive so I deleted the existing partition and then created a new one now called:
Partition1 [New<raw>] 190772MB
Unpartitioned space 8MB
I have then pressed 'enter' to set XP on the top partition1, however it says:
To install Winows XP on the partition you selected
Setup must write some setup files to the following disc:
305243 MB Disc 0 at Id 0 on bus 0 on atapi [MBR] NB. this is my other drive
However this disk does not contain a windows-XP compatible partition.
I can then only return to the main menu. I thought it would normally give me some option somewhere to format the hard drive to NTFS but it will not let me do this???
Any help would be really appreciated
