I'm trying to reformat an Acer Laptop 120GB hard drive that had problems before with VISTA so I'm using my copy of Win XP Pro, (I own the Volume disk, and have used it several times with no problems). When I try and do a reformat it hangs at 80%.
I've used MEMtest86, no erorrs, I've tried Ultimate bootCD, no probs, I've tried SystemRescueCD, no help. I ran CHKDSK from a DOS prompt no problems. I ws going to replace the MBR but it says that I might not be able to access my drive if it doesn't work...is that true ?
Right now I'm trying a MS-DOS FORMAT from a command prompt and its taking forever. After 20 minutes its only at 1%.
Any body got any suggestion ? I'd sure be grateful.
