Problems using Microsoft Flight Simulator 2002
G
Guest
Guest
Archived from groups: microsoft.public.simulators,microsoft.public.games.zone.simulation (More info?)
Hi,
I have get the Microsoft Flight Simulator 2002 and successfully installed it.
But if I want to
a) create a new fly, my computer slows down much (maybe cause of the little
3D model of the airplane)
b) fly, he needs much time to get all the data. But he already shows a
perfect picture.
c) fly some minutes, the Microsoft Flight Simulator 2002 hangs. But only the
simulator hangs. My computer is going on working.
Hardware:
AMD Athlon 700MHz
512MB RAM
128MB Winfast A180T (GeForce 4 MX 4000)
80 GB HDD
20 GB HDD
DVD-ROM LW
DVD-RAM LW (At Firewire Bus)
Sound Blaster Audigy 2 ZS
Side Winder Force Feedback 2
That are all optimal components to fly.
But why he hangs?
Also if I disable all programs in the background he makes this errors.
Is there somebody who can help me?
Regards
Christoph
P.S.
Sorry for my bad English, but I am a german.
Christoph Friedrich wrote:
> Hi,
> But if I want to
> perfect picture.
> Hardware:
> AMD Athlon 700MHz
> 512MB RAM
> 80 GB HDD
> 20 GB HDD
> DVD-ROM LW
> But why he hangs?
> Regards
> Christoph
> P.S.
Please post the results of running the DirectX Diagnostic video and
sound accelerator tests so that others with similar hardware can compare
their results and driver versions to yours. That information can be
obtained from the log file generated by the diagnostic when the button
to save information is clicked. Make sure you run the tests before you
click the button to save the diagnostic results. the disgnostic is
available through the System Information utility included with the last
several Windows versions or through the DXDIAG command typed in the Run
Popup. Make sure version numbers for DirectX and both video and sound
accelerators are in your post.
Here are the informations you wanted:
System Information
Time of this report: 2/15/2005, 21:45:17
Machine name: CHRIS
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack
1 (2600.xpsp1.020828-1920)
Language: German (Regional Setting: German)
System Manufacturer: Gigabyte Technology Co.
System Model: 7IXE
BIOS: Default System BIOS
Processor: AMD Athlon(tm) Processor, MMX, 3DNow, ~700MHz
Memory: 576MB RAM
Page File: 208MB used, 1102MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0b (4.09.0000.0902)
DX Setup Parameters: Not found
DxDiag Version: 5.03.0001.0902 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The file nv4_disp.dll is not digitally signed, which
means that it has not been tested by Microsoft's Windows Hardware Quality
Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware
manufacturer. DirectDraw test results: All tests were successful. Direct3D 7
test results: All tests were successful. Direct3D 8 test results: All tests
were successful. Direct3D 9 test results: All tests were successful.
Sound Tab 1: DirectSound test results: All tests were successful.
Music Tab: DirectMusic test results: All tests were successful.
Input Tab: No problems found.
Network Tab: No problems found. DirectPlay test results: The tests
were cancelled before completing.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: WinFast A180B
Manufacturer: Leadtek
Chip type: GeForce4 MX 4000
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0185&SUBSYS_2937107D&REV_C1
Display Memory: 128.0 MB
Current Mode: 1280 x 1024 (32 bit) (75Hz)
Monitor: Plug und Play-Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.5655 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 2/27/2004 05:34:56, 4163968 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: Nicht zutreffend
Mini VDD: nv4_mini.sys
Mini VDD Date: 2/27/2004 05:34:56, 1880320 bytes
Device Identifier: {D7B71E3E-42C5-11CF-DA65-3D0960C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0185
SubSys ID: 0x2937107D
Revision ID: 0x00C1
Revision ID: 0x00C1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {212DC723-3235-44A4-BD29-E1652BBCC71C}:
Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1)
Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}:
Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0)
DeinterlaceTech_BOBVerticalStretch
Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1)
Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0)
Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1)
Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0)
Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1)
Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0)
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: All tests were successful.
D3D7 Test Result: All tests were successful.
D3D8 Test Result: All tests were successful.
D3D9 Test Result: All tests were successful.
Sound Devices
Description: SB Audigy 2 ZS Audio [DA00]
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0004&SUBSYS_20021102&REV_04
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 5.12.0001.0442 (English)
WHQL Logo'd: Yes
Date and Size: 11/19/2003 03:13:54, 366160 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 4000, 192000
Static/Strm HW Mix Bufs: 64, 62
Static/Strm HW 3D Bufs: 64, 62
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: All tests were successful.
DirectInput Devices
Device Name: Maus
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Tastatur
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Microsoft SideWinder Force Feedback 2
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x001B
FF Driver: C:\WINDOWS\System32\swpdflt2.dll
FF Driver Date: 8/18/2001 04:54:26
FF Driver Version: 4.05.2600.0000
FF Driver Size: 10240 bytes
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB-Root-Hub
| Vendor/Product ID: 0x10B9, 0x5237
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/29/2002 01:32:50, 51968 bytes
| Driver: usbd.sys, 8/18/2001 11:00:00, 4736 bytes
Gameport Devices
+ PCI-Bus
| Matching Device ID: *pnp0a03
| Service: pci
| Driver: pci.sys, 8/29/2002 03:41:44, 62976 bytes
+-+ Creative Game Port
| | Matching Device ID: pci\ven_1102&dev_7003&subsys_00401102
| | Service: gameenum
| | Driver: gameenum.sys, 8/29/2002 01:32:44, 9856 bytes
PS/2 Devices
+ HID-Tastatur
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/18/2001 04:19:04, 14080 bytes
| Driver: kbdclass.sys, 8/29/2002 03:27:50, 24064 bytes
+ Erweiterte PC/AT-PS/2-Tastatur (101/102 Tasten)
| Matching Device ID: *pnp030b
| Service: i8042prt
| Driver: i8042prt.sys, 8/29/2002 03:22:04, 51584 bytes
+ Terminalserver-Tastaturtreiber
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/29/2002 03:43:46, 38024 bytes
+ Microsoft PS/2-Maus
| Matching Device ID: *pnp0f03
| Service: i8042prt
| Driver: mouclass.sys, 8/29/2002 03:38:58, 22528 bytes
+ Terminalserver-Maustreiber
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 51.4 GB
Total Space: 76.3 GB
File System: NTFS
Model: WDC WD800BB-60JKA0
Drive: D:
Free Space: 11.0 GB
Total Space: 19.6 GB
File System: NTFS
Model: WDC WD205AA
Drive: E:
Model: TOSHIBA DVD-ROM SD-M1612
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.1106 (German),
8/29/2002 01:27:56, 47488 bytes
Drive: G:
Model: I-O DATA CD-RW v1 IEEE 1394 SBP2 Device
Drive: F:
Model: AXV CD/DVD-ROM SCSI CdRom Device
System Devices
Device ID: PCI_HAL\PNP0A03\0
Driver: C:\WINDOWS\System32\DRIVERS\pci.sys, 5.01.2600.1106 (German),
Name: Creative Game Port
Device ID: PCI\VEN_1102&DEV_7003&SUBSYS_00401102&REV_04\2&EBB567F&0&41
Driver: C:\WINDOWS\system32\drivers\gameenum.sys, 5.01.2600.1106
(English), 8/29/2002 01:32:44, 9856 bytes
Name: OHCI-konformer IEEE 1394-Hostcontroller
Device ID: PCI\VEN_1102&DEV_4001&SUBSYS_00101102&REV_04\2&EBB567F&0&42
Driver: C:\WINDOWS\System32\DRIVERS\ohci1394.sys, 5.01.2600.1106
(English), 8/29/2002 01:33:20, 55680 bytes
Driver: C:\WINDOWS\System32\DRIVERS\1394bus.sys, 5.01.2600.1106
(English), 8/29/2002 01:33:20, 50560 bytes
Driver: C:\WINDOWS\System32\DRIVERS\nic1394.sys, 5.01.2600.1106
(English), 8/29/2002 01:33:32, 57984 bytes
Driver: C:\WINDOWS\System32\DRIVERS\arp1394.sys, 5.01.2600.1106
(English), 8/29/2002 01:33:30, 57344 bytes
Driver: C:\WINDOWS\System32\DRIVERS\enum1394.sys, 5.01.2600.0000
(English), 8/17/2001 13:46:40, 6400 bytes
Name: Creative SB Audigy 2 ZS (WDM)
Device ID: PCI\VEN_1102&DEV_0004&SUBSYS_20021102&REV_04\2&EBB567F&0&40
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.1106 (English),
8/29/2002 01:32:34, 57856 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.1106
(English), 8/29/2002 02:01:00, 134272 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.0000.0900 (German),
12/12/2002 00:14:32, 45696 bytes
Driver: C:\WINDOWS\System32\wdmaud.drv, 5.01.2600.0000 (English),
8/18/2001 04:55:14, 22016 bytes
Driver: C:\WINDOWS\System32\ksuser.dll, 5.03.0000.0900 (German),
12/12/2002 00:14:32, 4096 bytes
Driver: C:\WINDOWS\system32\drivers\ctac32k.sys, 5.12.0001.0443
(English), 11/5/2003 07:26:02, 645392 bytes
Driver: C:\WINDOWS\system32\drivers\ctaud2k.sys, 5.12.0001.0442
(English), 11/19/2003 03:13:54, 366160 bytes
Driver: C:\WINDOWS\system32\drivers\ctoss2k.sys, 5.12.0001.0441
(English), 10/8/2003 03:06:50, 178672 bytes
Driver: C:\WINDOWS\system32\drivers\ctprxy2k.sys, 5.12.0001.0441
(English), 10/8/2003 03:08:12, 6096 bytes
Driver: C:\WINDOWS\system32\drivers\ctsfm2k.sys, 5.12.0001.0441
(English), 10/8/2003 03:09:10, 130288 bytes
Driver: C:\WINDOWS\system32\drivers\emupia2k.sys, 5.12.0001.0442
(English), 10/13/2003 10:42:12, 145488 bytes
Driver: C:\WINDOWS\system32\drivers\ha10kx2k.sys, 5.12.0001.0444
(English), 10/21/2003 10:26:08, 904496 bytes
Driver: C:\WINDOWS\system32\drivers\haP16v2k.sys, 5.12.0001.0442
(English), 10/21/2003 10:23:44, 148432 bytes
Driver: C:\WINDOWS\system32\drivers\pfmodnt.sys, 3.00.0000.0003
(English), 3/5/2003 12:19:28, 15840 bytes
Driver: C:\WINDOWS\System32\ctdlang.dat, 10/21/2003 10:54:50, 217272 bytes
Driver: C:\WINDOWS\System32\ctstatic.dat, 10/21/2003 10:47:40, 298971 bytes
Driver: C:\WINDOWS\System32\ctdaught.dat, 10/21/2003 10:47:34, 53932 bytes
Driver: C:\WINDOWS\System32\a3d.dll, 80.00.0000.0003 (English), 10/6/2003
07:38:06, 65536 bytes
Driver: C:\WINDOWS\System32\commonfx.dll, 5.12.0001.0440 (English),
10/6/2003 07:44:28, 114688 bytes
Driver: C:\WINDOWS\System32\ctaudfx.dll, 5.12.0001.0441 (English),
11/18/2003 08:23:50, 585728 bytes
Driver: C:\WINDOWS\System32\ctsblfx.dll, 5.12.0001.0440 (English),
10/6/2003 07:46:14, 606208 bytes
Driver: C:\WINDOWS\System32\sfman32.dll, 5.12.0001.0130 (English),
8/17/2001 07:35:46, 36864 bytes
Driver: C:\WINDOWS\System32\ctbas2w.dat, 10/21/2003 10:54:48, 140643 bytes
Driver: C:\WINDOWS\System32\ctsbas2w.dat, 10/21/2003 10:54:42, 264466 bytes
Driver: C:\WINDOWS\System32\SBAudigy.ico, 8/17/2001 05:42:28, 7406 bytes
Driver: C:\WINDOWS\System32\Audigy.bmp, 11/13/2001 02:48:20, 1912 bytes
Driver: C:\WINDOWS\System32\ctcoinst.dll, 3.00.0000.0004 (English),
10/6/2003 07:48:30, 69632 bytes
Driver: C:\WINDOWS\System32\ctdvinst.dll, 0.00.0000.0008 (English),
10/6/2003 07:48:42, 143360 bytes
Driver: C:\WINDOWS\system32\drivers\ctdvda2k.sys, 5.13.0001.0413
(English), 10/14/2003 04:17:56, 332800 bytes
Name: Realtek RTL8029(AS)-PCI-Ethernetadapter
Device ID: PCI\VEN_10EC&DEV_8029&SUBSYS_802910EC&REV_00\2&EBB567F&0&60
Driver: C:\WINDOWS\System32\DRIVERS\RTL8029.sys, 5.508.0803.2000
(English), 8/17/2001 12:12:40, 19017 bytes
Device ID: PCI\VEN_10DE&DEV_0185&SUBSYS_2937107D&REV_C1\3&2B508F69&1&2808
Driver: C:\WINDOWS\System32\DRIVERS\nv4_mini.sys, 6.14.0010.5655
(English), 2/27/2004 05:34:56, 1880320 bytes
Driver: C:\WINDOWS\System32\nv4_disp.dll, 6.14.0010.5655 (English),
Driver: C:\WINDOWS\System32\nvinstnt.dll, 6.14.0010.5655 (German),
2/27/2004 05:34:56, 131072 bytes
Driver: C:\WINDOWS\System32\nvsvc32.exe, 6.14.0010.5655 (English),
2/27/2004 05:34:56, 77824 bytes
Driver: C:\WINDOWS\System32\nvoglnt.dll, 6.14.0010.5655 (English),
2/27/2004 05:34:56, 4841472 bytes
Driver: C:\WINDOWS\System32\nvcpl.dll, 6.14.0010.5655 (English),
2/27/2004 05:34:56, 2899968 bytes
Driver: C:\WINDOWS\System32\nvmctray.dll, 6.14.0010.5655 (English),
2/27/2004 05:34:56, 46080 bytes
Driver: C:\WINDOWS\System32\nvwddi.dll, 6.14.0010.5655 (English),
2/27/2004 05:34:56, 35840 bytes
Driver: C:\WINDOWS\System32\nvwdmcpl.dll, 6.14.0010.5655 (English),
2/27/2004 05:34:56, 1609728 bytes
Driver: C:\WINDOWS\System32\nvnt4cpl.dll, 6.14.0010.5655 (English),
2/27/2004 05:34:56, 241664 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 2/27/2004 05:34:56, 87403 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 2/27/2004 05:34:56, 49796 bytes
Driver: C:\WINDOWS\System32\nvcod.dll, 1.00.0000.0014 (English),
2/27/2004 05:34:56, 31744 bytes
Driver: C:\WINDOWS\System32\nvcodins.dll, 1.00.0000.0014 (English),
Name: USB (Universal Serial Bus)-Controller
Device ID: PCI\VEN_10B9&DEV_5239&SUBSYS_523910B9&REV_01\2&EBB567F&0&5B
Driver: n/a
Name: ALi PCI-zu-USB Open Host-Controller
Device ID: PCI\VEN_10B9&DEV_5237&SUBSYS_523710B9&REV_03\2&EBB567F&0&5A
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.1106
(English), 8/29/2002 01:32:50, 15744 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.1106
(English), 8/29/2002 01:32:52, 135552 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.1106 (English),
Driver: C:\WINDOWS\System32\usbui.dll, 5.01.2600.0000 (German), 8/18/2001
04:54:32, 70144 bytes
Device ID: PCI\VEN_10B9&DEV_5237&SUBSYS_523710B9&REV_03\2&EBB567F&0&59
Device ID: PCI\VEN_10B9&DEV_5237&SUBSYS_523710B9&REV_03\2&EBB567F&0&58
Name: AMD 756 PCI-zu-USB Open Host-Controller
Device ID: PCI\VEN_1022&DEV_740C&SUBSYS_00000000&REV_06\2&EBB567F&0&3C
Name: AMD-756 Energieverwaltungscontroller
Device ID: PCI\VEN_1022&DEV_740B&SUBSYS_00000000&REV_03\2&EBB567F&0&3B
Driver: n/a
Device ID: PCI\VEN_1022&DEV_7409&SUBSYS_00000000&REV_07\2&EBB567F&0&39
Driver: C:\WINDOWS\System32\DRIVERS\pciide.sys, 5.01.2600.0000 (German),
8/18/2001 11:00:00, 3328 bytes
Driver: C:\WINDOWS\System32\DRIVERS\pciidex.sys, 5.01.2600.1106 (German),
8/29/2002 01:27:48, 23680 bytes
Driver: C:\WINDOWS\System32\DRIVERS\atapi.sys, 8/29/2002 01:27:50, 86912
bytes
Name: PCI Standard-ISA-Brücke
Device ID: PCI\VEN_1022&DEV_7408&SUBSYS_00000000&REV_01\2&EBB567F&0&38
Driver: C:\WINDOWS\System32\DRIVERS\isapnp.sys, 5.01.2600.0000 (German),
8/18/2001 11:00:00, 36224 bytes
Name: AMD-751 PCI-zu-PCI-Brücke
Device ID: PCI\VEN_1022&DEV_7007&SUBSYS_00000000&REV_01\2&EBB567F&0&08
Driver: C:\WINDOWS\System32\DRIVERS\amdagpxp.sys, 5.33.2600.0001
(English), 12/11/2001 14:52:12, 27776 bytes
Name: PCI Standard-Host-CPU-Brücke
Device ID: PCI\VEN_1022&DEV_7006&SUBSYS_00000000&REV_25\2&EBB567F&0&00
Driver: n/a
Name: ATI Technologies Inc. 3D RAGE II+ PCI
Device ID: PCI\VEN_1002&DEV_4755&SUBSYS_00000000&REV_9A\2&EBB567F&0&48
Driver: C:\WINDOWS\System32\DRIVERS\atiragem.sys, 5.01.2493.0000
(German), 8/18/2001 04:19:52, 70784 bytes
Driver: C:\WINDOWS\System32\atiraged.dll, 5.01.2493.0000 (English),
8/18/2001 04:52:42, 104832 bytes
Name: A347SCSI SCSI Controller
Device ID: PCI\A347SCSI\0000
Driver: n/a
DirectX Components
ddraw.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 284160
bytes
ddrawex.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 24064
bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 10496
bytes
d3d8.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 1177600
bytes
d3d8thk.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 8192
bytes
d3d9.dll: 5.03.0001.0902 German Final Retail 5/30/2003 09:00:02 1634304
bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 436224
bytes
d3dim700.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 797184
bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 590336
bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 350208
bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 47616
bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 34816
bytes
dplay.dll: 5.00.2134.0001 German Final Retail 8/18/2001 11:00:00 33040
bytes
dplayx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 217600
bytes
dpmodemx.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 77824
bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/18/2001 11:00:00 42768
bytes
dpwsockx.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 76800
bytes
dplaysvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 28160
bytes
dpnsvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 16896
bytes
dpnet.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 723968
bytes
dpnlobby.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072
bytes
dpnaddr.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072
bytes
dpvoice.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 381952
bytes
dpvsetup.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 80896
bytes
dpvvox.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 112128
bytes
dpvacm.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 19968
bytes
dpnhpast.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 32768
bytes
dpnhupnp.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 68096
bytes
dpserial.dll: 5.00.2134.0001 German Final Retail 8/18/2001 11:00:00 54032
bytes
dinput.dll: 5.01.2600.1106 German Final Retail 8/29/2002 03:43:20 156160
bytes
dinput8.dll: 5.01.2600.1106 German Final Retail 8/29/2002 03:43:20 173568
bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 44032
bytes
diactfrm.dll: 5.01.2600.0000 German Final Retail 8/23/2001 05:00:00 467968
bytes
joy.cpl: 5.01.2600.1106 German Final Retail 8/29/2002 03:43:42 66560
bytes
gcdef.dll: 5.01.2600.0000 German Final Retail 8/23/2001 05:00:00 223232
bytes
pid.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:43:28 31744
bytes
gameenum.sys: 5.01.2600.1106 English Final Retail 8/29/2002 01:32:44 9856
bytes
dsound.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 355328
bytes
dsound3d.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
1294336 bytes
dswave.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18432
bytes
dsdmo.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 186880
bytes
dsdmoprp.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 491520
bytes
dmusic.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 116736
bytes
dmband.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 27136
bytes
dmcompos.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 58368
bytes
dmime.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 171520
bytes
dmloader.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 33280
bytes
dmstyle.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 98816
bytes
dmsynth.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 100864
bytes
dmscript.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 76800
bytes
system.dll: 1.01.4322.0573 English Final Retail 2/1/2005 18:42:40 1216512
bytes
dx7vb.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 602624
bytes
dx8vb.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 1189888
bytes
dxdiagn.dll: 5.03.0001.0902 German Final Retail 5/30/2003 09:00:02 1675264
bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/18/2001 11:00:00 924432
bytes
mfc42.dll: 6.00.8665.0000 English Beta Retail 8/18/2001 11:00:00 995383
bytes
wsock32.dll: 5.01.2600.0000 German Final Retail 8/18/2001 11:00:00 23552
bytes
amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 64512
bytes
devenum.dll: 6.05.0001.0902 German Final Retail 5/30/2003 09:00:02 132608
bytes
dxmasf.dll: 6.04.0009.1125 German Final Retail 8/29/2002 03:43:20 499741
bytes
mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 34304
bytes
mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 136192
bytes
msdmo.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 13312
bytes
encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18944
bytes
qasf.dll: 9.00.0000.2926 English Final Retail 10/28/2002 11:18:04 221184
bytes
qcap.dll: 6.05.0001.0900 German Final Retail 12/12/2002 00:14:32 257024
bytes
qdv.dll: 6.05.0001.0900 German Final Retail 12/12/2002 00:14:32 311808
bytes
qdvd.dll: 6.05.0001.0902 German Final Retail 5/30/2003 09:00:02 449024
bytes
qedit.dll: 6.05.0001.0900 German Final Retail 12/12/2002 00:14:32 1798144
bytes
qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 733184
bytes
quartz.dll: 6.05.0001.0902 German Final Retail 5/30/2003 09:00:02 1962496
bytes
strmdll.dll: 4.01.0000.3928 German Final Retail 8/29/2002 03:43:32 251904
bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/18/2001 11:00:00 199680
bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/18/2001 11:00:00 848384
bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/18/2001 11:00:00 120320
bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/18/2001 11:00:00 338432
bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/18/2001 11:00:00
755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/18/2001 11:00:00 200192
bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/18/2001 11:00:00 183808
bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/18/2001 11:00:00 154624
bytes
mswebdvd.dll: 6.05.0001.0900 German Final Retail 12/12/2002 00:14:32 324096
bytes
ks.sys: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 130304
bytes
ksproxy.ax: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 117248
bytes
ksuser.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 4096
bytes
stream.sys: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 45696
bytes
mspclock.sys: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 5248
bytes
mspqm.sys: 5.01.2600.0000 German Final Retail 8/23/2001 05:00:00 4608 bytes
mskssrv.sys: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 7424
bytes
swenum.sys: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 4096
bytes
mstee.sys: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 5504
bytes
bdaplgin.ax: 5.03.0000.0900 German Final Retail 2/17/2003 10:16:26 16896
bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 11392
bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:26 52224
bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:28 354816
bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:28 30208
bytes
ipsink.ax: 5.03.0000.0900 German Final Retail 2/17/2003 10:16:26 14848
bytes
mpeg2data.ax: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:26 57856
bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 10112
bytes
mpe.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 15104
bytes
streamip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 14976
bytes
msvidctl.dll: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:28 1230336
bytes
slip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 10880
bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 83968
bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 16384
bytes
vbisurf.ax: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:30 27648
bytes
msyuv.dll: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 16896
bytes
kstvtune.ax: 5.03.0001.0902 German Final Retail 6/4/2003 10:30:32 274432
bytes
ksxbar.ax: 5.03.0001.0902 English Final Retail 6/4/2003 09:18:28 39424
bytes
kswdmcap.ax: 5.03.0000.0900 German Final Retail 2/17/2003 10:16:32 226304
bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:32 18688
bytes
wstdecod.dll: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:32 47104
bytes
msdv.sys: 5.01.2600.0000 English Final Retail 2/17/2003 10:21:50 52096
bytes
I hope you can help me now.
Please help me.
I want to fly.
Regards
Christoph
