Hi All,
Don't know if this is the best spot to ask but at least its a starting point.... I built a new system recently and its been giving me a fair bit of grief, basically what happens is that you will be using the computer and then it just stops responding. The HDD light comes on solid but it doesn't matter if you are browsing the net or playing a game or anything else it will just sit there for what can be up to a few minutes...
Sometimes the computer recovers, sometimes it blue screens on me, the interesting thing I have just picked up on is that when I hit the reset button after the blue screen I get a message "Reboot and select proper boot device" and when I check in the BIOS my primary SSD drive is showing up as NOT PRESENT.
This will continue each time you reset until you hit the power button and shutdown the system completely... then things work as normal until the next time it happens.... I can go days without it happening then get it 4 times in 10 minutes...
Here is a small capture of the last blue screen with what I reckon are the import details
STOP: 0x000000F4 (0x0000000000000003, 0xFFFFFA800A861880, 0xFFFFFA800A861B60, 0xFFFFF800035CCF40)
Also get Physical memory dump failed status 0xC0000010
If anyone could help me out it would be greatly appreciated, its ruining what was meant to be a great new family treat 🙁
Cheers
Cheers
