Question Processor Running but Display, Mouse and Keyboard not working
bala_4370
21
Dear All,
My system suddenly did not show anything in monitor and Mouse, Keyboard as well did not work, but the Processor is running. I did all basic troubleshooting like removing and fitting the RAM, removing the CMOS battery and putting it back - Nothing worked.
Later I replaced the CMOS battery with a new one and now it is booting into BIOS setting, I changed the Date and time and when I click on Save and Exit, it goes blank again and the monitor, mouse and keyboard dont work.
Again if I remove the battery and fit it again, the same thing happens.
Please help.
Santhosh.
statistx
Commendable
Jul 16, 2019
9
Dear All,
Please help.
Santhosh.
I thought this was my thread, cause i have the same issue.
Not sure if it helps for you, guess since you removed the CMOS you already did that, but USUALLY it works if I unplug everything including power, then wait for a good 10-20 minutes, plug everything back in and boot again.
Not sure what it is, I am now replacing my MOBO, cause that seems to be the most likely culprit, but you can go here and see if anything from my thread helps: https://forums.tomshardware.com/threads/mobo-faulty-pc-turns-on-but-screen-and-any-usb-peripherals-stay-dark-sometimes-works-for-days-or-months-but-then-suddenly-the-issue-is-there-again.3743922/
bala_4370
21
Thanks, will try disconnecting all cables, powercord etc and try again. But I need a solution as I do not have money to buy new components :(
