Product Key code for Wondows XP CD
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I have crashed my computer. To re install, I need the product code for my XP
CD disk, and I cannot locate this. I don't know who manufactured my compute
(custom built) and Microsft ca't seem to help me. Any ideas on how to help me?
If your computer is still operational:
Retrieve your Windows XP CD key
http://michaelstevenstech.com/ViewKeyXP.htm
[Courtesy of Michael Stevens, MS-MVP]
If your computer is not operational:
How to Replace Lost, Broken, or Missing Microsoft Software or Hardware
;326246]http://support.microsoft.com/default.aspx?scid=kb;[ln];326246
Carey Frisch
Microsoft MVP
Windows XP - Shell/User
Be Smart! Protect Your PC!
http://www.microsoft.com/athome/security/protect/default.aspx
> for my XP CD disk, and I cannot locate this. I don't know who
> manufactured my compute (custom built) and Microsft ca't seem to
> help
The Windows 25-character Product Key (required to perform the
installation) is stored on the CD packaging on a bright orange sticker
that says "Do not lose this number." It is not on the installation CD
in any way, shape, or form. If it was an OEM (factory installed)
license, it's stored on a label that the PC manufacturer affixed to
the exterior of the PC case, or on the bottom of a laptop.
To recover a lost Product Key:
If your system still runs, you should be able to use Belarc
Advisor from http://www.belarc.com/free_download.html to find the
Product Key. (If you have a factory-installed OEM license, and
haven't since reinstalled the OS, the revealed Product Key is probably
of the drive image used at the factory and not your specific Product
Key; therefore, it probably cannot be -- and definitely should not
be -- used for a re-installation.)
If it was a retail license and you have proof of purchase:
http://support.microsoft.com/default.aspx?scid=KB;en-us;326246
If it was an OEM license, you should contact the computer's
manufacturer; although very few manufacturers/vendors keep records of
the Product Keys they've sold, it's worth a try before you have to buy
a new license.
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
You can have peace. Or you can have freedom. Don't ever count on
having
both at once. - RAH
I tried this link and it does not work. The key given comes up invalid. It
can not really find your product key code because your actual key it is
encrypted on your computer. Unfortuanetly you will have to purchase from
Microsoft. Good Luck!🙂
> Carey Frisch
> Microsoft MVP
"computergal" <computergal@discussions.microsoft.com> wrote in message
news:7E4BEE4D-F719-43BF-960F-A5483DDCC9B1@microsoft.com...
It
These utilities do in fact work. The encryption isn't very strong. (also,
be careful on things like mistaking 1's for I's, A's for R's, and 8's for
Bs).
*However*, if you use the detected key with another form of install CD
(say, an OEM key with upgrade install or retail CD) the key will indeed be
invalid. You need to use the correct key- media pair.
One thing you may be able to do is locate the \i386 folder, and burn its
complete contents to CD. Use a boot diskette (with Smartdrv.exe and CD
drivers), go to the \i386 folder on teh CD and run "winnt.exe". This is
almost guaranteed to be the correct file set and installer version.
HTH
-pk
> > Carey Frisch
> > Microsoft MVP
my XP
compute
help me?
