Question PS3 heat spreader came out. Am i done?
Jul 4, 2021
So i disassembled the ps3 i just bought today to replace thermal paste of it. When i tried to take the mobo out, it wouldn't so i searched web for it. Found a forum about it and the comments were saying wiggle more it will come out so did i. But heat spreader of gpu or cpu idk came out and dye was exposed. Am i done? What can i do about it? Please it's urgent.
https://www.hizliresim.com/bduhydv
https://www.hizliresim.com/4w9hzhg
(This site is Turkish alternative to imgur so its safe dont worry)
I have thermal pads can i use them for somehow reapply the thermal spreader?
Not done exactly but you should be able to put the IHS back on. It just shows that the IHS was probably delidded to apply that white thermal pad/paste.
Thanks! So in theory i can re-apply thermal compound on the dye and ihs and it can run normally right? Also i have MX-4 will that a problem?
