Ps4 to monitor
On a PS4? I think their issue is that they don't know if the monitor has an HDMI port or not (Which it does).
That monitor actually doesnt have an HDMI port mate, just 1 x Displayport. It doesn't come with speakers and it uses DP purposely to achieve 1440p @ 144Hz.
TBH, Its just not designed to be used with a console bud !!!
They don't need an adapter in the first place, though. The monitor has an HDMI port they can use :/
No, (for the third time :) ) it doesn't have an HDMI port mate !! The 271 does, but not the 270.
Sorry for confusion. Monitor only has one DP port. Can anyone recommend an active two way adaptor.
Only other option would be to buy a cheap 1080p monitor to use with it? But then I feel like I'm losing the Pro features only running at 1080p...
Thought???
Thanks, that link now worked.
Based on the other forum, it may not even work if I was to get the adapter.
Leaning towards getting a second monitor with hdmi exclusively for console gaming. That way it's sure to work and avoids all the messing around
That's what consoles are designed for? What? They probably just prefer being up close to a monitor.
