[SOLVED] PSU fan running at 100% after 2 years
ankido
134
Hi,
As of a week ago my PSU which I found was the culprit is revving up to 100% most of the time. Sometimes it takes a break for a minute and goes back to running at 100% speed. Not sure what is causing this. I forgot what brand it is I want to guess Corsair. It's been two years with no issues and now the fan decides to run instead of walk.
What should I do after blowing air in it and that didn't fix the issue. Time to replace the PSU?
Note: The fan is at the bottom blowing air UP into the case.
Which psu exactly? If still under warranty could you rma.
I would have to dig inside the case to find out which. It's 2 years old. Now every time I turn it on the fan is at 100% and it scares me. I don't want to fry anything in my system. I'm not sure what's causing this. It sits up on a small office desk alone good airflow around it no smoke no nothing. Not sure why it would get a lot of dust if that was the case. I've tried airing it out and nothing.
This is what I see while my PSU fan is going haywire on idle.
NZXT! I'm gonna be real with you guys. I banged the case. Banged on top of the PSU after it froze on me doing a 1hr and 30 minute podcast. Then I wiggled the power plug and yanked it out. Plugged it back in and now she's quite quiet. I'm so confused. Maybe I needed to beat it up?
Two people ask what psu you have (and jonnyguru want's to know all specs) and your response is "i beat the psu" where i guess you mean the pc and which you shouldn't do, not with a pc not with any other electrical device.
So again what psu? = maker+model+wattgae. And for jonnyguru what other parts as well?
Intel i9 9900k
RTX 2070
Rog Maximus XI Hero
Ultra X3 1000W ATX Power Supply
Update!
Just installed
Seasonic FOCUS Plus 650 Gold SSR-650FX 650W 80+ Gold ATX12V & EPS12V Full Modular 120mm FDB Fan Compact 140mm Size Power Supply, Gold Modular FX
Problem solved!
This PSU is extremely quite. So far so good. Wish me luck. It was a smooth bootup.
Reactions: Vic 40
