[SOLVED] PSU Problems, please help me
A good quality 500 watt psu should be able to handle it easily but do not get any adapters just get a new psu. Adapters could have to much power ect and short/burn. You are going to need a 8. Pin for that gpu.
The in I daily drive and use is the Corsair CS650M but seasonic,Asus,evga all make good psu’s
Ah thank you so much, do you think that's the cause of no signals to monitor?
its designed not to work if all of the connectors are not plugged
never get adaptors , as the molex cables arent designed to handle that load
buy a new quality psu , where are you located and what is your budget ?
