The more I think about this topic, this thought did come to mind: The fact that more and more PSUs are using cheaper caps due to shortages makes the Segotep GP 600w seem even more appealing to me. The main complaint I have about it is the cheap capacitors, after all. If the competition is also doing cheap caps, it doesn't seem so bad in comparison. Would still really want to see a review though.
I have used it for about 6 months for testing computers. I was originally going to use it in one system but ended up going for something different, so it just stuck around, and having no better use, I just throw it into any pc that needs a PSU temporarily anymore.
I did test the Segotep with an overclocked i7 990x and GTX590 (dual thermi with power consumption on par with an RTX3090) and never had any issues with it during prime 95 and Furmark simultaneously. It was probably being run dam near 100% capacity the entire time. But then again, 100% capacity shouldn't be an issue.
Ironically, my Enermax Platimax DF 500w, which is basically the segotep minus 100w but with a lot better component quality also has no issues with this combo, which goes to show how much wattage you really need.
