Made me lol! I couldn't agree more.IMHO, the words electricity and budget should not be seen in the same paragraph.
5 years. But that might not mean much. These days even Seasonic understands that they are only likely to see maybe 3 out of 10 faulty units actually come back by way of RMA because the majority of users with a cheap component will simply write it off and replace it with something better, or something locally and therefore more readily, available. So they can afford to give a lower quality unit a longer warranty because in most cases they are never going to see it again when it fails anyhow.How long is the warranty?
Another CX600 thread, that was found guilty. I thought by now those things would all be dead. LOL.
https://forums.tomshardware.com/thr...clean-install-with-ddu.3697669/#post-22291594
Wow, thanks for tearing it up, @--SID-- ! You must be rich getting PSUs like that and voiding the warranty like a boss just for us to see..
Jokes aside, I have honestly never heard of Helly. Seems like an obscure OEM like RSY and all that. But thankfully the platform looks modern. Yate Loon fans, Ltec and AsiaX caps, not so good. Am I right? Maybe @jonnyguru can comment on the fan and cap choice, because all I know is that these are bad chocies (I might be wrong). But to be frank, I'd still put it on the class of MWE V2, TUF Bronze, and Corsair CX non-modular. Maybe the worst one out of those but still in the same class.
However I still hate Seasonic for doing this. Why can't they make a good successor to the S12II? It's simple, just design something with modern topology (LLC and D2D), use at least Hong hua fans, and Teapo/Elite caps. Job done!
Looks like maybe stock in Rubycon, Nichicon and Sanyo/Suncon ought to go up then. LOL.Also, Japanese brand caps are getting hard to find BTW. As you may know, Hitachi divested itself of it's factory last year and Chemi-Con just announced that a raw material used in their KY series is no longer available so they're going to EOL that product line.
Of course, that has the undesirable effect of causing units using those parts to also go up, so you lose some and you wi...eh, nah, you just lose some these days.
So who's left that makes good caps?
I'm just going to tell everyone to buy RM instead of RMx. LOL! I know how the sausage is made. 😀
Pretty sure we have no idea WHICH tier list you are talking about, since there are several of them and they range from laughable to merely "has some flaws". Much as I've disagreed with some of the opinions of the folks doing the LTT tier list that we ALSO allowed to list it here, it's definitely better than anything else out there right now. And that does not necessarily say much. BUT, it's also clear that you won't end up with a crap unit using it either, and might end up with a lesser known GOOD unit if you do.I saw that PSU tier list, the thermaltake thoughtpower grand rgb gold is tier a and the thoughtpower gf2 is tier c? I'm shocked that psu was release last year, why is that bad?
Fair enough, but since Corsair, ASUS, and Cooler Master are able to do it, they being one of the most famous brand in the PC building market should be able to do it. They at least should do Bronze in Taiwan, it won't cannibalize their Gold line up if the problem is tariffs.They can't make a good successor to the S12II because it would cost too much. Seasonic fan boys are buying Focus and Prime. Not Bronze. The Bronze market is way too much of a commodity market these days. And with China tarrifs in the U.S. being 25%, the cost of a good Bronze encroaches into Made in Taiwan Gold territory (which is only a 10 to 15% cost adder to assemble SKD PSUs in Taiwan). So if it costs 10% more to make Gold and 15% more to build an SDK in Taiwan, then it costs the same as a (good quality) Chinese made Bronze.
How about Su'cson? Are they not good or are they having supply demand problems as well?Elite. Teapo. Nichicon.
https://www.eteknix.com/thermaltake-gf2-argb-750w-premium-edition-review/9/?amp=1
This was the review cited. It doesn't seem that bad.
Would ask them about their tiering, not us.
I am confused now, is it a capacity problem, a tariff problem, or a bit of both? If it's both why don't they design their own decent bronze platform (which I'm pretty sure they're capable of), and make someone else manufacture it? I mean this is essentially what they did with the B12 and G12, but they don't want to spend extra cents on better components?That's like saying Koenigsegg is the most famous car brand and they should be able to scale to GM's capacity. In the grand scheme of things, Seasonic is actually quite small.
