PUBG System Settings
viperits8
8
Hey Guys, since all of you know PUBG has skyrocketed through the roof. This makes me have some questions. I saw the minimum system requirements to play the game, but at what setting will I be able to play with a Ryzen 5 1600x and a GTX 1050ti SC? Also how much FPS will i get? Thanks :)
you should be able to play at med to high settings at a pretty constant 60fps. Although remember that it is an early access game which means fps wont always be consistent. i have an i7 4770k and a GTX1070 and it still dips bellow 60fps every once in while.
Duncan_94
67
Play on the lowest settings with only AA at ultra and textures at ultra (if you want to play to win that is). Remember to use launch options as well (I use: -USEALLAVAILABLECORES -malloc=system -high -maxMem=16000 +Vt_maxPPF16 -refresh 144). Change -maxMem to what you have.
