Hi!
I just finished my first ever PC build using the Fractal Design Define S2 Vision Blackout case and have some issues with how to set up the fan hub.
The case has 4 fans which according to the manual should be connected to a PWM hub to the back of the case.
The manual also states that the CPU fan cable should connect to that same hub which then connects to a CPU_Fan header on the mothercard which is powered by a SATA-connection.
https://www.fractal-design.com/wp-content/uploads/2019/06/Define-S2-Vision_Manual-13.91-MB.pdf
(page 7)
However my CPU fan cable is too short to reach the hub and I have to buy an extension cable.
My question is regarding whether you think it's an good idea to connect everything to the CPU_Fan header as recommended by the manual or if I should connect the PWM hub to one of the Case fan header, and then connect only the CPU fan to the CPU_Fan header and control the case fan speeds by BIOS instead?
Thankful for any advice with this issue
(page 7)
