G
Guest
Guest
Archived from groups: comp.dcom.lans.ethernet (More info?)
Hello all!
My question is about coupling desktop class gigabit switches with
autouplink ports (like Netgear GS608 or D-Link DGS-1005D).
I have 3 rooms each with 3-5 PCs in. Is it possible to place a desktop
switch (like the ones above) in each room and have them interconnected
via the normal autouplink-ports?
How about a "full connection", I mean each switch uplinking to both
other switches. (A to B , B to C and C back to A)
Will this give connection redundancy and better performance in any
way? Or will it help me in case that any one uplink cable fails or
gets disconnected?
Or will it mess up traffic somehow if there are more than 1 way from
switch A to C (once directly via cable and once via switch B)?
Well I will have no VLANs and all PCs will be in the same IP subnet.
No NETBIOS used.
Hopefully my question will not be too confuse ;o)
Thanks in advance,
Michael
Hello all!
gets disconnected?
No NETBIOS used.
Thanks in advance,
Michael
