Hi all,
I have a strange problem with my q6600 cpu.
its at 9x333=3.0ghz
I'm using Antec NSK2480 case, and its got 2 case exhaust fans and they can be adjust low,med and high speed.
when both fans are set to low, my full load is about 61C and it runs fine, no crashes or anything, but i noticed that the cpu sometimes lowers the multi to 6x333 (which normally happens when idle), but it shouldnt as its 100% load.
i tested again when i set just one of the fans to medium speed, and the cpu will clock at the correct load frequency which is 9x333, and stays at 9x333.
i thought it might be the temp throttling? but the temp is pretty much the same still at 61C with one of the fan at med speed.
so my question is why did it throttle?
hope i explained my problem clear enough...
please advice
its at 9x333=3.0ghz
please advice
